Activity Forums Apple Final Cut Pro Legacy Error Message: Movie must be rendered before it can be encoded
  • Error Message: Movie must be rendered before it can be encoded
    Posted by Alfi Randy on February 5, 2007 at 5:01 pm
    I keep getting this error message in FCP when I try to encoded to Mpeg2 via Quicktime Conversion even if the movie is completely rendered. Has anyone encountered this before? And when I try to do it in Compressor, it just fails right away. Any ideas on why this is happening? Thanks!
    Serenity now…
    David Roth weiss replied 19 years, 7 months ago 2 Members · 3 Replies
  • David Roth weiss
    February 5, 2007 at 5:20 pm
    Don’t know why you’re getting that message, but more importantly, why use QT conversion? Compressor is a better choice and it will do AC3 audio encoding simutaneously too.
    DRW
  • Alfi Randy
    February 5, 2007 at 6:15 pm
    Thanks for the reply David. I’ve always used Compressor but for some reason everytime I try to use it now, the batch fails right away. It’s not even trying to process the batch, it just quickly fails as soon as I hit submit. Have you had this problem before? Thanks!
    Serenity now…
  • David Roth weiss
    February 5, 2007 at 6:30 pm
    Sounds like you’re due for a reinstall… Thanksfully everything here is working well.
    DRW
