Activity Forums VEGAS Pro Error message: An exception occured
  • Error message: An exception occured
    Posted by Chris Parker on August 5, 2007 at 1:07 pm
    When I try to open a saved file with a project I’ve been working on the message appears: ‘An error occured during the current operation. An Exception has occured’.
    It only started doing this recently, it never used to and I can’t think of anything I might have changed.
    Can anyone help?
    Douglas Spotted eagle replied 19 years, 1 month ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    August 6, 2007 at 2:36 pm
    Installed any new software? Increased RAM? Changed rendering threads? These are all candidates for failing/error.
    You might have a corrupted file as well. Can you locate the .bak version of the file?
    Douglas Spotted Eagle
    VASST
    Aerial Camera
  • Chris Parker
    August 15, 2007 at 4:28 pm
    I just went back to the file to play it through again and continue working on it. It’s happened before on another file some months ago but on a different computer.
    I’ve had trouble locating the .bak file, even though some saved files are easily found. Where’s the best place to look?
    August 16, 2007 at 7:12 am
    Search feature, then *.bak will turn them all up for you.
    VASST
    Aerial Camera/Instructor
    Certified Sony Vegas Trainer
