Activity Forums Adobe After Effects Error Message again
  • Error Message again
    Posted by Dolver on January 15, 2007 at 10:02 pm
    Sorry for the double post, but nobody seemed to want to answer my question. Very sad. Well, here’s one more go at it:
    When I try to export my project, I get and error message:
    After Effects error: Quicktime export failed — Out of memory (-108).
    What can I do to fix this and be able to export my project? Thanks folks.
    Also, I am on Windows using AE 7.
    Steve Roberts replied 19 years, 8 months ago 2 Members · 5 Replies
  • Steve Roberts
    January 15, 2007 at 10:07 pm
    More details, please:
    1. Did you use file>export or the render queue?
    2. To which codec did you render?
    3. What is your frame size (comp size)?
  • Dolver
    January 15, 2007 at 10:13 pm
    Thanks for the response Steve —
    1. I used file>export
    2. I am trying to export it as quicktime (H.264)
    3. Comp size is 640×480
  • Steve Roberts
    January 15, 2007 at 10:15 pm
    Maybe you should use the render queue to make a Quicktime movie in the animation codec, then use Quicktime (Pro?) to convert to H.264.
  • Dolver
    January 15, 2007 at 10:58 pm
    woo hoo! seems to work — thanks!
  • Steve Roberts
    January 15, 2007 at 11:11 pm
    Excellent. 🙂
