Activity › Forums › Apple Final Cut Pro Legacy › Error message after capture
Posted by Nate Owens on October 21, 2005 at 1:20 pmI’m pulling my hair out trying to figure out what this problem is. After capturing a logged clip, I get one of two messages:
Error: Final Cut Pro was unable to read the movie file just captured
or
File error: unknown file
FCP acts otherwise normal during the capture process, with my MEDEA SCSI drive blinking and everything. Nothing gets saved to the drive though. I just cleaned that drive and it’s up to full capacity of 613GB.
FCP HD 4.5
OS X 10.3.9
Power Mac G4 1.4mhz
Cinewave RT
ATTO UL3D
MEDEA RTS 5/240 hard driveI hope someone can help!!
Thanks – Nate
Nate Owens replied 20 years, 10 months ago 3 Members · 13 Replies -
Rich Harrison
October 21, 2005 at 2:47 pmI would suggest your problem is caused in one of two areas:
Either (and most likely) your Cinewave RT card or possibly your SCSI connection. First and formost, restart the system. Check all cables both SCSI and Cinewave. Also be sure the drivers and dashboard for Cinewave haven’t been blasted away from a previous crash and are up to date.
Rex -
Nate Owens
October 21, 2005 at 7:09 pmDidn’t work. Reinstalled Cinewave hardware and software, reconected cables, nada. Did I maybe not trash all of the preferences I needed to?
Nate
Nate Owens
October 22, 2005 at 8:48 pmHi Don. Thanks for responding. I did trash those preferences and still no luck.
Nate
Don Greening
October 22, 2005 at 11:10 pmOkay. The reason I asked about the FCP prefs is because I had the exact same issue and trashing the prefs cured the problem. FCP would capture to the hard drive, then at the end would tell me that I had bad TC and would delete the capture file. At the risk of sounding redudant (redundant, redundant)……double-check that you’ve trashed all the FCP prefs. Here’s a link on how to do it properly:
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
If you’re now saying: “enough already. I did all that” then you might try starting a brand new project and try capturing again, because you might have a corrupt project file or sequence file within that project. If that works you can capture away and then drag the files into your present project’s capture scratch folder and then just import them from within the browser. If you’ve already done all this then disregard my ramblings.
Just some thoughts.
– Don
Nate Owens
October 23, 2005 at 4:04 amHi Don – thanks again for offering your help. I’ll have to wait until Monday am when i’m back in the office. I’ll keep you posted.
Nate
Nate Owens
October 24, 2005 at 4:22 pmHi Don. I trashed the preferences and still same problem. i then uninstalled FCP and reinstalled and still had the problem. I’m about ready to lose my mind! What is so odd is that the capture process all acts “normal”. It just keeps giving that stupid file unknown message. Could this be a Quicktime issue? Thanks again for helping me out.
Nate
Don Greening
October 24, 2005 at 4:41 pmI dunno, Nate. I’m out of ideas now. I would suggest you start a new thread outlining your problem so it’ll be front and centre up at the top of the FCP forum page and in everyone’s face. Um, and creat a link in your post to your original thread down here.
I can only relate to you what has worked for me in the past with similar problems, but I have no experience with Medea hard drives or your Cinewave capture card since I work only with Mini DV and firewire. I noticed that you’re a little short on RAM for your G4 but if everything’s been working fine up till now the RAM thing might not be so much of an issue.
– Don
Don Greening
October 24, 2005 at 11:07 pmForgot to ask if you’ve ever tried to capture to another hard drive other than the Medea. Your startup drive, for example, just to run a test.
– Don
