Activity › Forums › Apple Final Cut Pro Legacy › Error in FCP
Error in FCP
Posted by Josh Fischel on April 22, 2008 at 10:52 pmI am trying to output a sequence in Final Cut. I am outputing as a quicktime file with no compression and it gets halfway through the output and says Error: File too large
Arnie Schlissel replied 18 years, 4 months ago 5 Members · 6 Replies -
Shane Ross
April 22, 2008 at 11:07 pm#3 Output lossless Quicktime movies
Shane’s Stock Answer #3: How to output lossless Quicktime movies
To export your project so there is no loss in quality, simply go to the File Menu and select EXPORT>QUICKTIME MOVIE. Not Quicktime Conversion, for this will compress the footage. Make sure the settings match your timeline settings, make it self contained, do NOT recompress the footage, and you are set.
https://library.creativecow.net/articles/ross_shane/fcp_faq.php
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Richard Harrington
April 23, 2008 at 1:01 amAlso make sure the drive you are going to is mac formatted or you’ll hit a 2GB file limit
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Mitch Ives
April 23, 2008 at 5:05 am[Richard Harrington] “Also make sure the drive you are going to is mac formatted or you’ll hit a 2GB file limit”
Actually, it’ll just make series of smaller files in the Capture scratch folder that are white and have no icons, but the 2GB file limit won’t stop you from capturing a larger file. I inadvertently did that last week when a friend asked me to capture some footage for them to a firewire drive that they dropped off. After capture, I discovered all those small files and realized it was a PC formatted drive…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com -
Richard Harrington
April 23, 2008 at 5:13 amHe’s EXPORTING not capturing…
Mitch Ives
April 23, 2008 at 2:04 pmSorry, obviously I can’t read… one of the problems of answering when you’ve been working too many hours…
Mitch Ives
Arnie Schlissel
April 23, 2008 at 7:57 pm[Josh Fischel] “Error: File too large”
That means you don’t have enough space on the target drive. You’ll need to remove some files to open up space & export again.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
