Activity › Forums › Adobe After Effects › ERROR!!! Footage turns white using HD+Masks
Posted by Howden on September 18, 2006 at 8:29 amMy footage keeps previewing/rendering WHITE after a 4-5 seconds!! I think it is related to using masks….but I need the masks for junk mattes! Any fixes/ideas???? I’ve tried swicthing OpenGL on/off, and the source footage seems fine in other progs….
Howden replied 20 years ago 3 Members · 7 Replies -
Aharon Rabinowitz
September 18, 2006 at 12:29 pmI get that when RAM is low. Try purging thew memory and previewing smaller sections at a time by shotening your work area. HD footage takes upa lot of RAM.
Edit > Purge > All (Gets rid of undo’s and image cache).
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Roland R. kahlenberg
September 18, 2006 at 2:20 pmI suggest you take a look at using proxies. Serge has a great tutorial here at the COW. Just to add to his tutorial, proxies also work great when moving files from one system to another. All you need to do is to move the proxies and work with those on another system. When it comes time to render your final output, just switch to the system that has the high-rez files and all will be fine.
HTH
Roland Kahlenberg
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files -
Aharon Rabinowitz
September 18, 2006 at 3:03 pmAndrew also has a video tutorial here:
Aharon Rabinowitz
Howden
September 19, 2006 at 1:21 amGreat, thanks!
I’ve got 2GB now, should I go for 4GB? Any other tweaks in AFX?Limiting the previews seems to work but what about rendering the finals? I could render in five second increments but then will have a lot to cut together in AVID.
Thanks again for your help!
Howden
September 19, 2006 at 1:26 amThanks, yeah I havn’t had to use proxies before but it makes sense with HD.
Any thoughts on final renders? I’ll still need to render from the raw footage and then the video layer will go white after about 5sec.
Aharon Rabinowitz
September 19, 2006 at 1:57 amWatch this tutorial on dumping the ram cache durring a render:
Aharon Rabinowitz
Howden
September 19, 2006 at 6:37 amExcellent, purging the cache every 15 frames totally worked!!
Thanks so much for your help, and your tutorials are fantastic!
