Activity › Forums › Apple Final Cut Pro Legacy › Error encountered (L&C)
  • Error encountered (L&C)
    Posted by Din Noor on January 22, 2009 at 5:28 am
    I have 2sets of mac pro 10.5 (M1 & M2). Happens when i log & cap on M1, there is an error note as follows:
    “Capture encountered a problem reading the data on yr source tape.This could be due to a problem with the tape.Capture has been aborted & yr clip has been saved.”
    When i log & capture the same clip on my M2, it works fine without any error notice.
    Both of my settings are identical.
    Can anyone guide me on what to do?
    thank you..
    Rgds:
    Sam
    be calm & patience.
    Din Noor replied 17 years, 8 months ago 2 Members · 2 Replies
  • Andy Mees
    January 22, 2009 at 6:45 am
    Are you also using the same camera/deck and same cable for the capture in both instances?
  • Din Noor
    January 22, 2009 at 7:52 am
    Yes Andy,
    i do use the same camera & cable too. Hope to hear from u soon..thks
    be calm & patience.
