Activity Forums VEGAS Pro Error creatin bla bla.mp4
  • Error creatin bla bla.mp4
    Posted by Nasser Daoud on March 19, 2016 at 2:52 pm
    Don’t ask but I have a 17 hour video, I’m rendering in mp4, cpu only 720p, low bitrate etc. It renders fine until like 75-80%, it will say error creating .mp4 error cannot be determined. I do have enough space to render it. Lowering quality doesn’t work neither but regardless, Id rather have hd at least 720p than lower quality.
    How can I fix.
    Wayne Waag replied 10 years, 5 months ago 3 Members · 2 Replies
  • Mike Kujbida
    March 19, 2016 at 3:22 pm
    I’m assuming that you’ve checked your media at the 75-80% mark to make sure nothing is bad.
    If it’s ok, try frameserving it from Vegas Handbrake. This method works beautifully and is easy.
    Follow all the steps at https://www.vegasvideo.de/vegas-2-handbrake-en and you’ll get your video in 720 or 1080 if you want it. Good luck.
  • Wayne Waag
    March 19, 2016 at 5:45 pm
    For something that long, you may want to consider breaking your video down into a number of shorter productions, render each one, and then re-combine using software that will smart-render such as VideoRedo or TMPGEnc’s MPEG Smart Renderer. Or, if your program has some natural breaks such as fade to black, you could simply re-combine the individual videos using freeware such as FFMPEG.
    wwaag
