Activity › Forums › Apple Final Cut Pro Legacy › Error Code -36
  • Posted by Naomi Greenfield on December 6, 2005 at 5:21 am
    I’m trying to transfer the media files off my internal harddrive onto a firwire exteranl drive. The files seem to transfer (and some do so with no problems) but many of them say they are unable to transfer due to Error code -36? Anyone else get this? Any suggestions on a better way to transfer media from internal to external?
    Harley Michailuck replied 20 years, 10 months ago 4 Members · 3 Replies
  • Don Greening
    December 6, 2005 at 5:27 am
    Is this firewire drive a new one? If so, make sure it’s formatted in MacOS Extended (Journaling off).
    – Don
  • Annaël Beauchemin
    December 6, 2005 at 6:56 am
    this error means that a drive has a bad block.
    Verify the SMART status of your drives in Disk Utility. A bad drive will show “Failed” in red. Unfortunately, OS X doesn’t suport SMART for FW drives…
  • Harley Michailuck
    December 6, 2005 at 1:49 pm
    [Naomi Greenfield] “many of them say they are unable to transfer due to Error code -36? Anyone else get this? Any suggestions on a better way to transfer media from internal to external?”
    Had this happen to a FW drive about a month ago… a few days later it finally gave up and I had to have it replaced under warranty.
    Backup to a different drive and get this one repaired or replaced… it will eventually die on you.
    Best,
    Harley
    Harley Michailuck
    Brass Orchid Post fx
    Saskatoon, SK Canada
    https://www.brassorchid.com
