Activity › Forums › Apple Final Cut Pro Legacy › Error 50
Error 50
Posted by Jimmy Stewart on October 10, 2006 at 5:38 pmI’m using compressor in FCP to export audio to bring into dvd studio pro…and at 30% it stops and says “error 50” and it fails. what is the problem? all other sequences work, and the video compresses fine
thanks!
Jimmy Stewart replied 19 years, 11 months ago 2 Members · 6 Replies -
Ed Dooley
October 10, 2006 at 5:50 pmI don’t know if this helps at all, but Error 50 is a common error when using OSX
in a shared network with Windows machines. It’s also common for hard drive I/O
problems when using drives formatted for PC/Mac. Are you on such a network? Or are
you using an external drive that may be formatted as Fat32? Is anything else different
from the last exports of other sequences?
Ed -
Jimmy Stewart
October 10, 2006 at 6:38 pmim using a mac g4 that was just upgraded to tiger. im not on a network…just editing out of my home. fcp is 4.5. the first sequence compressed no problem; the second is the same media just one minute longer. im also getting “general error” messages sometimes when i render the audio…but it will eventually let me render after a few trys. then compressor is giving me QuickTime error50. all other tests work..just for some reason this sequence has problems.
i tried erasing all renders and rerendering, but it still is givng me problems.
i also have my media on a lacie 250 drive formatted for mac.
any thoughts?
thanks, ed
Ed Dooley
October 10, 2006 at 7:01 pmI’ve also read of corrupt files or sequences causing this. Two possible things to try:
-First create another sequence and copy the timeline to that
-If that doesn’t work, duplicate the sequence, and using the duplicate, remove
one clip at a time of the clips that are different from the timelines that work (you
said they’re the same except the one with errors is a minute longer, right?). After
eliminating each clip, try compressing again to isolate the potential corrupt file.
A long process perhaps, but it’s all I can suggest (oh, trash your prefs too).
Ed -
Ed Dooley
October 10, 2006 at 7:19 pmUsers/UserName/Library/Preferences/
You should read these (easily found on a search):
https://www.kenstone.net/fcp_homepage/basic_troubleshooting_fcp_jordan.html
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
https://docs.info.apple.com/article.html?artnum=302337
https://docs.info.apple.com/article.html?artnum=93385Ed
Jimmy Stewart
October 10, 2006 at 8:55 pmi will check out all of those links. thanks
btw, i singled out each section of the sequence and pasted into a new sequence and they all worked individually. but as soon as i put them together, or split it in half, the error came up. not sure why..it didnt single out one file as corrupted. it just cant handle the larger volume. its only a 19min sequence.
i compressed the audio in sections and ill try to lay them side-by-side in dvd studio pro. hopefully they will line up properly.
thanks for the help.
jimmy
