Activity Forums Storage & Archiving Error-50 code when attempting video file transfer to Cache-A LTO4 Device
  • Error-50 code when attempting video file transfer to Cache-A LTO4 Device
    Posted by Stanton Kellam on July 28, 2015 at 9:24 am
    I am trying to transfer video files to my LTO Cache-A device and the transfers are failing. The error message I get is: ““The Operation can’t be completed because an unexpected error occurred. (error code -50) ” It is not one particular file but different files from different external drives. Any ideas on what could be going on? I have tried different Mac’s and the Cache-A has new drives and latest software. The Mac and Cache-A device are networked using a Belkin router. I appreciate any advice from active Cache-A / Mac users.
    Tom Goldberg replied 11 years, 1 month ago 2 Members · 3 Replies
  • Tom Goldberg
    July 29, 2015 at 3:09 pm
    Hi Stanton,
    This problem may or may not be the one documented in the user manual – did you try that solution? If not, let me know, there may be other things to try.
    User Manual on Error -50:
    Macintosh issues with the LTFS Volume:
    Mac OS versions may have issues with what they refer to as “named streams” when dropping folders onto the LTFS Volume and cause the Mac Finder to report an “Error -50” upon dropping content onto the LTFS Volume. If you see this error, you can eliminate it by following the steps in the Apple Knowledge Base report covering this topic:
    To disable named streams as a default for all Mac OS X client user accounts on a Mac
    Log in to Mac OS X with an admin user account if you aren’t already logged in as an admin, then execute these two commands in Terminal:
    echo “[default]” | sudo tee -a /etc/nsmb.conf
echo “streams=no” | sudo tee -a /etc/nsmb.conf
    Note that if it was mounted, you will have to unmount and remount the Cache-A share after applying these terminal commands.
    For more information about this issue and other options for dealing with it, please refer to the information posted at https://support.apple.com/kb/HT4017 on the Apple web site.
    This issue can also be avoided by mounting a Macintosh share on the Cache-A appliance with the Mount Manager facility, and using the File Manager in the web user interface for your operations.
    Tom Goldberg
    TGCS
    30201 Rainbow Hill Rd.
    Evergreen, CO 80439
    mailto:tomgoldberg@gmail.com
    https://tomgoldberg.net
  • Stanton Kellam
    July 31, 2015 at 11:44 pm
    I really appreciate the help Tom. Not being a code guy I have some questions with the commands:
    I assume the “[default]” is entered exactly like that or is [default] something else?
    Also – what is the character “I” between “[default]” and sudo tee. Is it a capital I or a 1 or a Lower case L?
    Thanks for the clarification. – sk
  • Tom Goldberg
    August 1, 2015 at 3:27 am
    Sorry for the confusion,
    Yes – use “[default]” exactly as it appears
    The vertical bar is called a “pipe” sign in Linux/Unix (and Mac) and is typed with the shift-backslash on a mac keyboard
    You can actually copy and paste the commands from my post to do this most easily.
    Good Luck!
    Tom Goldberg
    TGCS
    Evergreen, CO 80439
