  • Posted by Paolo Mugnaini on July 29, 2009 at 4:05 pm
    Hi I am trying to render a complex timeline, but everytime I try I get the ” unable to allocate space for a 5000 x 2500 …”
    It’s the first time this is happening, I’ve tried to export in intermediate, PNG but still no success.
    However it does render the proxy with no problems.
    Any suggestions?
    thanks
    Paolo
    Paolo Mugnaini replied 17 years, 1 month ago 2 Members · 5 Replies
  • Chris Wright
    July 29, 2009 at 10:16 pm
    I use to have this problem too, and after a while determined how to fix it.
    I actually leave the mem settings alone and simply do the following:
    1. Max disk cache size 15000 mb
    2. Secret purge every 1 frame
    3. Set Window’s Virtual Memory to 8000 initial and max
    I can now do extremely huge files really really fast with no crashes or image buffer errors.
  • Paolo Mugnaini
    July 30, 2009 at 6:13 pm
    Chris,
    Thanks but I am running MAc OS X
  • Chris Wright
    July 30, 2009 at 7:43 pm
    Mac OS X does not use a preallocated swap partition for virtual memory. Instead, it uses all of the available space on the machine’s boot partition. So,
    1. is your boot hard drive full?
    2. are you running 30 widgets?
    3. edit – purge all before rendering plus secret purge every 1 frame and disk cache 15000 mb tweak
  • Paolo Mugnaini
    August 6, 2009 at 1:26 pm
    “3. edit – purge all before rendering plus secret purge every 1 frame and disk cache 15000 mb tweak”
    Thanks for the info but i do not not where to purge before rendering.
    thanks
    Paolo
  • Paolo Mugnaini
    August 6, 2009 at 1:52 pm
    OK…Sorry I found the purge but not the secret purge.
    P
    FCP 5.1.4 – PowerMac 2.2 Dual – 4.5 Gb Ram
    1Tb G-Raid2 – 2 1Tb Lacies- CUBASE SX3
