Activity Forums Adobe After Effects error ( 23 :: 0 ) illegal XML Character “”
  • Bouke Vahl
    February 16, 2018 at 12:38 pm
    It means that there is are illegal xml charachters in the xml. And those are double quotes.
    the error message is quite helpfull!
    Replace the quotes (inside the quotes) with " and you should be fine.
    Bouke
    http://www.videotoolshed.com
  • Wilko Morsink
    February 16, 2018 at 1:29 pm
    Hello Bouke,
    Thanks for your quick response,
    Could u explain me where the XML Characters can be found?
    And should I need to look in the imported file or in the project I’m working in?
    Regards
    Willy
