Activity Forums VEGAS Pro Error
  • Error
    Posted by Courtney Smith on August 15, 2009 at 8:17 pm
    I’ve just recently had my computer cleared of all previous memory because some of the files were infected by viruses. However, before the files could be deleted, I stored them on my sister’s laptop by using a memory stick to transfer them. As far as I know, none of the memory was lost in the process; the files still look the same.
    But now, when I loaded Sony Vegas 8.0 and the project that I was working on back onto the computer, there was an error message that read:
    Warning: An error occured accessing project media.
    Some streams in the media file could not be opened.
    And the only thing that loads on is the audio.
    Is there a certain codec that I need for this?
    John Rofrano replied 17 years, 1 month ago 2 Members · 10 Replies
  • 10 Replies
  • Courtney Smith
    August 15, 2009 at 9:48 pm
    What I mean is, when I try to replace the files that say “Media Offline” on them, I get that error message.
    The actual project file loads on fine, it’s just that all of the videos that I used IN the project won’t load on.
    Sorry that I didn’t make that clear in my last post.
  • John Rofrano
    August 16, 2009 at 3:16 am
    It sounds like you have a missing codec. Use a tool like GSpot to determine which codec the files use and then install the codec that is needed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Courtney Smith
    August 16, 2009 at 3:52 am
    GSpot says that the Codec is installed.
  • John Rofrano
    August 16, 2009 at 2:19 pm
  • Courtney Smith
    August 17, 2009 at 2:08 am
    Okay. I downloaded GSpot again, and now it says that the codec is NOT installed. It indicates that I need an xvid codec. Is that a good codec to download?
  • John Rofrano
    August 17, 2009 at 10:57 am
    Vegas does not work well with Xvid or DivX so don’t bother trying to edit them directly. You’ll need to re-encode those files into something that Vegas can edit if you really want to edit them. You can get Xvid from xvid.org. You’ll still need a program to convert the files to DV or M-JPEG or Lagarith or some other codec that Vegas can edit. Lots of people use Super(c) to convert files. Google for it.
    ~jr
  • Courtney Smith
    August 17, 2009 at 6:06 pm
    When you say that “Vegas does not work well with Xvid or DivX,” what exactly do you mean? Because I downloaded Xvid, and now all of my files are opening properly. Why would I need a converter like Super(c)?
  • John Rofrano
    August 18, 2009 at 2:17 am
    Have you tried to render any of your projects? This is usually where Xvid and DivX get into trouble with Vegas; the renders have problems like jerky playback, green blocks and other artifacts, etc. Just make sure that you can render without problems.
    ~jr
  • Courtney Smith
    August 18, 2009 at 2:38 am
    “Just make sure that you can render without problems.”
    And, if I cannot, then would I convert my source media with the Super(c) codec?
  • John Rofrano
    August 18, 2009 at 10:30 am
    Yes, exactly. That’s where people have trouble and converting the files seems to clear it up. Just do a test render and see so that you don’t get too far along and realize that it’s not working.
    ~jr
