Activity › Forums › DaVinci Resolve › erasing void after a cut
  • erasing void after a cut
    Posted by Alex Gat on March 4, 2021 at 9:12 am
    Hello,
    Very common edit I guess, I cut a clip in three, I remove the middle part and I select and delete the void to reduce my clip.
    Thing is, sometime in a complex timeline I guess, at least with two or three video/audio tracks, some track move along and some other stay put even though they are linked together (and then the little red label appears telling me I have a delay).
    I wanted to ask you if you’d had that bug before and according to you what could be the cause of it (and yes I carefully sliced each clip with the snap on and I unlocked all tracks).
    Thanks for your input.
    Alex
    David Baud replied 5 years, 6 months ago 2 Members · 1 Reply
  • David Baud
    March 5, 2021 at 4:33 am
    Two things I can think of:
    . make sure you have all the Auto select track actives (Resolve Ref. Manual p584)
    . if you need to delete gaps between your clips in your timeline, you can use the Edit > Delete Gaps command (Resolve Ref. Manual p592)
