Activity › Forums › Adobe Photoshop › Erasing a image…
Erasing a image…
Posted by Robert William on August 28, 2008 at 3:17 pmHi,i have this image https://images.encyclopediadramatica.com/images/d/d1/Fageminators..jpg i wanted erase a person front of other one without earing the one behind it.how can i do that?
Jeff Kelley replied 18 years ago 4 Members · 5 Replies -
Todd Morgan
August 29, 2008 at 1:56 amDo you mean cutting out a person but still keep the person standing behind them, body and all?
Paul Benson
September 1, 2008 at 5:35 pmDepends on which one you want to remove.
Consider covering the person that is no longer part of your clown posse with a ‘sign’ (ex – Clown Party 2008), or a plant.
Or, if you do not care about the size of the pic, pull the other two clowns up and crop the bottom.
Pauley
Jeff Kelley
September 2, 2008 at 7:11 pmAs said above, photoshop can’t fill in the area that you want to remove. If you remove a person, you’ll just be left will a blank spot of some color left where he or she was.
The idea of covering the guy with a plant is the easiest.
