Activity Forums Apple Final Cut Pro Legacy Erase-oops-suggestions
  • Erase-oops-suggestions
    Posted by Nate on October 26, 2006 at 12:57 am
    Well after three plus years editing with FCP, I really oops.
    I had 2 firewire drives on the desk top, using the Disk Utility I erased one and it was the wrong one. I just changed the disk name. I have not saved anything to that disk yet. Does anybody know of a method for retrieving the data.
    Thanks for your suggestions.
    Will Salley replied 19 years, 10 months ago 3 Members · 2 Replies
  • Walter Biscardi
    October 26, 2006 at 1:17 am
    I would call the drive company’s tech support immediately and see if they can help you. Most drive manufacturers can either attempt a retrieval or will refer you to a company that can try.
    Man, I can totally feel your pain, best of luck with that.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Will Salley
    October 26, 2006 at 1:40 pm
    Data Rescue worked for me a few months back when I did something equally idiodic – I trashed my entire current project folder instead of just a single folder, and then emptied the trash before I realized what I had done. Data Rescue II was able to retrieve most of the standard filetypes, but NOT FCP project files. I luckily had these in the autosave vault. It does take time – a large media drive would require 12 hours or more for retrieval.
    https://www.prosofteng.com/products/data_rescue.php
