Activity › Forums › Apple Final Cut Pro Legacy › Equivalent of AE Adjustment Layer?
  • Equivalent of AE Adjustment Layer?
    Posted by Michael Lazar on February 1, 2006 at 11:02 pm
    I’m wondering if there’s a way to add something like an adjustment layer (ala After Effect) to an FCP sequence. Purpose of this would be – for example – to apply the Broadcast Safe filter to all of the clips in all of the tracks in the sequence. Right now I’m nesting the sequence to do this – I’m hoping there’s a better – less clunky – way.
    Thanks in advance!
    Michael Lazar
    Jeremy Garchow replied 20 years, 8 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 1, 2006 at 11:59 pm
    you cant do what you’re doing in an adjustment layer sense, but you can set up a filter on one clip. Drag that to your favorites folder in the browser, select the rest of the clips and drag that filter to those clips.
    or
    You can set up a filter on one clip, then hit copy (apple-c), select the rest of the clips you want to add the filter to and hit Past Attributes (Option-v). Select the filter tickbox and then it’s pasted to all of the clips. This method is okay if you only have the one broadcast safe filter on the original clip, otherwise it’ll paste all of the filters you have on the original clip to the rest of the clips.
    Nesting is okay to do as long s you don’t have to media manage as nesting can get goofy with the media manager.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Michael Lazar
    February 2, 2006 at 1:49 am
    Thanks for the tip.
    Seems like this (an adjustment layer) would be a cool feature for a future rev.
    Michael
  • Jeremy Garchow
    February 2, 2006 at 3:18 am
    Track level filters would be cool. You can request this feature here:
    https://www.apple.com/feedback/finalcutpro.html
