Activity › Forums › Apple Final Cut Pro Legacy › Episode Pro not cooperating
  • Episode Pro not cooperating
    Posted by Chris Poisson on March 1, 2007 at 9:29 pm
    I am making a 24p widescreen DVD, from 24p DV material, and Episode’s resulting 5mbs m2v files will not go into DVDSP. It’s saying it’s not a compatible format. There are settings for frame rate and everything in there, and the resulting m2v files are beautiful, but DVDSP won’t take them.
    Anyone seen this? BTW, trying Bitvice with the same file it says on launch that 23.98 is not a framerate it supports, but when I get past that alert, there are settings for 23.98, and it does a beautiful encode, but DVDSP won’t take that file either. Only Compressor is setting the frame rate automatically and making files I can use in DVDSP, and this is all from the same master file.
    Chris Poisson replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
