Activity Forums DaVinci Resolve Epic HDRx 3 Identical files
  • Epic HDRx 3 Identical files
    Posted by Dave Williams on October 20, 2011 at 7:57 pm
    I recently did the dailies on a Red Epic HDRx job and will be doing the finals but on some of the folders I noticed that there were 3 identical files. They are are all different in size. Has anyone ever seen this? I am new to the HDRx work flow and not quite sure what the 3 files are for. Anyone shed some light on this?
    Robert Pitman replied 14 years, 11 months ago 4 Members · 4 Replies
  • Sascha Haber
    October 21, 2011 at 8:59 am
    Just one question, do you have set the file extensions to be hidden ?
    Red files will be split every 2 GB and the segments are named the same .
    I know, its like asking if you plugged in the power, but anyway 🙂
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Gabriele Turchi
    October 21, 2011 at 4:17 pm
    as sascha say
    HDRX does not produce extra R3D files , everything is just bigger size and embedded inside the same R3D files …
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Robert Pitman
    October 25, 2011 at 1:43 am
    Hello Dave,
    Does the R3D look like the attached image?
    EPIC R3Ds are 4 GB split.
    The only thing you need to check, does REDcineX (Pro or normal) see the shot as one continues shot with the HDRx A and X track?
    Cheers,
    Robert
  • Robert Pitman
    October 25, 2011 at 3:36 am
    Sorry typed too quickly – meant to say:
    The only thing you need to check, does REDcineX (Pro or normal) see the shot as one continuous shot with the HDRx A and X track?
    Cheers,
    Robert
