Activity › Forums › Apple Final Cut Pro Legacy › eos plugin problem
  • eos plugin problem
    Posted by Colin Kennedy on February 24, 2012 at 8:10 pm
    Hello, I just installed the eos plugin for fcp so that my dslr footage could be logged and transfered. I downloaded the plugin, and when I insert my sd card and open up the log and transfer window, it reads my card but no clips show up. Maybe I missed a step in the installation process? Any ideas would be greatly appreciated. Thanks-
    -Colin
    Shane Ross replied 14 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 25, 2012 at 12:40 am
    Which camera? If it’s not the 5D, 7D or 1D, you need to edit the plugin file.
    And as good practice, don’t import directly from the card. Back up the card first, THEN import.
    Workflow:
    Little Frog in High Def
