Activity › Forums › Apple Final Cut Pro Legacy › EOS plugin doesn’t bring in full clip
Posted by Mike Throck on August 9, 2010 at 6:08 pmI’m using the Canon EOS plugin for FCP to log and transfer my footage from the CF cards.
However, many clips aren’t fully imported and they are much shorter than they are on the card.
Anyone else had this problem?
Randy Lee replied 16 years, 1 month ago 7 Members · 8 Replies -
Shane Ross
August 9, 2010 at 6:22 pmI haven’t, no. Using the Canon T2i and a hacked L&T plugin…so that the T2i footage would work.
Shane
Read my blog, Little Frog in High Def -
Jason Brown
August 9, 2010 at 7:51 pmHad same problem.
Check out this posting…3rd post down was my solution.
https://forums.creativecow.net/thread/280/1281
Mike Throck
August 9, 2010 at 7:57 pmThanks Jason,
I haven’t tried your solution yet, but I did notice that the guy you we’re talking to said he was “scrubbing the timeline” when the transfer stopped.
If I let the transfer go without clicking on any clips in the browser of viewer then it comes in fine. Once I start clicking on things in FCP is when I run into problems.
I’d be interested to see if you’re fix solves that problem.
thanks again
Dave Gorrie
August 9, 2010 at 9:22 pmI’ve yet to nail down a solution to this – it seems to be more prominent in 5D footage as opposed to 7D footage. We are taking on a LOT of projects revolving around this format, and would love for some kind of fix. This seems like it’s a L&T issue really – I’ve seen it happen on P2 stuff before, but not as often as it is happening now.
Let me know if anyone has any other solutions for this.
-D
Michael Gissing
August 10, 2010 at 2:01 amFirst time I used the L&T canon with 5D material, I had three clips that didn’t fully import. I was opening already converted clips and playing them in FCP Viewer while L&T was running.
I deleted and re transfered the three clips and they came in full length second time. Since then I leave FCP alone while L&T is running and no problems since.
It is a bit like Log & Capture really. Just let it do it without trying to continue editing. Boring yes, but it seems to be necessary for reliable L&T with the Canon plugin.
John Pale
August 10, 2010 at 11:05 pmHad this happen recently with 7D footage. Yes..it appears to be best not to do anything in FCP while L & T is doing it’s thing. Never had a problem when I just left it alone and did not try to continue working.
Mike Throck
August 11, 2010 at 12:40 amLooks like we found a bug in Canon’s plugin.
At least we know how to avoid it.
Randy Lee
August 11, 2010 at 5:37 pmWhen I had this issue recently on a short film, no matter how many times I attempted to bring in the affected clips through L&T, they came in shortened. I didn’t shoot the film, so it may have never been noticed except that something seemed off when the audio that I was syncing continued but the video ended abruptly. Clips were from a 7D, and I ended up bringing them through Mpeg Streamclip, then adding reel and TOD timecode information from inside of Final Cut. It’s kind of scary – no warning, and it would be really easy to miss something if you’re not paying attention to every single clip, especially if you don’t know what was shot.
Hopefully there’s a fix soon. Or at least an update to the plugin that will tell you that something is amiss.
