Activity Forums Maxon Cinema 4D Engraving Help Please
  • Engraving Help Please
    Posted by Darren Kunkel on October 31, 2009 at 3:53 pm
    Hey Guys-
    The question here PLEASE is in regards to ENGRAVING. My goal is to have a pipe (exhaust pipe in my case for a car) with engraved text on the surface. The pipe is implemented as a Circle Spline and Text Spline subordinate to a SWEEP NURBS object.
    I’ve read up on and tried the following approaches:
    -Bump Map
    -Extruded Text with WRAP deformer
    -Have yet to try Polygonal displacement
    Would you please offer your advice on how you would approach this? Again, I’m attempting to engrave some text (4-5 letters in length) on the surface. They all look terrible. 🙂
    Thanks in Advance to this Forum!!
    -Darren
    Darren Kunkel replied 16 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 31, 2009 at 5:04 pm
    A bump map should work fine. Subpolygon displacement would work even better, but would be more cpu and memory intensive. What was the problem with your bump experiment?
  • Darren Kunkel
    October 31, 2009 at 11:07 pm
    Hi Adam-
    As always, thanks for the quick response. BTW, I of course meant that I was using CIRCLE spline for sweeping…not a TEXT spline. Sorry about that.
    If OK by you, I’ll render out the pipe utilizing the bump map and attach to this thread. Thanks again
