Activity Forums Adobe Encore DVD endless encoding of animated buttons
  • endless encoding of animated buttons
    Posted by Thomas Fink on March 10, 2011 at 11:35 am
    I have a problem with the render time using animated buttons with CS5.
    I’ve done a menu template with Photoshop (1920×1080, 12 animated buttons, background picture).
    After assigning chapter and generating index I started to render the menus.
    But 1/4 of one menu take more then 8h (QuadCore 4Ghz) and I have 14 menus.
    The problem is that only one core is used by encore for rendering the menu. So only around 25% CPU by encore.exe is used.
    It also does not use AME even if I have set it in the option.
    Is there a different way how menus are rendered compared to the timeline?
    Is it possible to render the animated menus by AME not by encore?
    Thomas Fink replied 14 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Daniel Ludwig
    March 10, 2011 at 2:50 pm
    hi thomas,
    there is no other way then encode menus within encore! this is a stupid thing!
    even if you take previously encoded assets encore will transcode them again to MPEG2HD – and this as well when your project-transcoding-settings are set to H264.
    if you have time for a walk, and would like to get in BD-spec-authoring you should have a look at EasyBD + IGEditor.
    https://www.dvd-logic.com/
    If you´ll learn how to use it, this is a great application-combination.
    there are demo-versions available.
    cheers
    danny
  • Thomas Fink
    March 10, 2011 at 6:37 pm
    Thanks for the info but I cannot believe that the rendering of the menus will take that long and only uses on core.
    Since this would need days for transcoding just one 15s animated menu.
    I still think this is a setting or a configuration problem.
    It would be interesting if others have the same issue that transcoding of menus with animated buttons will take that long.
  • Daniel Ludwig
    March 10, 2011 at 8:57 pm
    the answer is NO.
    what are you using? MAC or PC?
    cheers
    danny
  • Thomas Fink
    March 10, 2011 at 9:39 pm
    Its a PC and CS5.
  • Daniel Ludwig
    March 10, 2011 at 9:58 pm
    thomas,
    there must be something wrong on your configuration.
    I´m using CS5 on different mac computer (desktop and laptop) and it´s everywhere running fast.
    cheers
    danny
  • Thomas Fink
    March 14, 2011 at 8:28 am
    The long encoding problem was removed after uninstalling different video SW and codec packs. I don’t know what exactly it was but it’s much faster transcoding now.
  • Daniel Ross
    July 17, 2011 at 6:18 pm
    Dan, thanks for chiming in that you use Encore CS5 on a Mac — my problem is similar to those reported. I have the animated motion menus in my DVD project (TV Menu & TV Submenu). When I render the project, the first HOURS are devoted to rendering the menus. This morning, for example, I started it at 1115 and now, 8 menus later at 1416, it just finished cooking the menus.
    I’m running Encore CS5 on a Late 2009 iMac with 4gb of RAM, and the files live on a hard-wired outboard media drive. All other programs are closed.
    I noted that the TV Menus are pre-defined to not transcode, which I thought was odd, but lots of this is new to me.
    I’d love to know how to do this faster. Any ideas??
    best!
    DCR
  • Thomas Fink
    October 30, 2011 at 12:30 pm
    I think I found a solution of this Encore bug:
    First I start Premiere and then Encore since the Encore timeline is connected to Premiere.
    Second I clean the Encore media cache in the preferences.
    When I start then the rendering of the motion menus the rendering is faster.
    Which of the two things mentioned above fixes this issue I don’t know yet, maybe both of them.
    The strange thing is that if I look in the processes, the Premiere process is running between 30-60% the Encore process only 10-20%.
    But still the quadcore CPU is by far not utilized and the hard disk is also not busy.
    The motion menue rendering is not efficiently programmed.
    BR
