Activity Forums Media 100 “End of File” message
  • “End of File” message
    Posted by Rick Spencer on July 12, 2011 at 11:57 pm
    I am getting a “Could not open project because end of tape. Please advise what to do, this is a new project and no other projects are having this problem.
    Floh Peters replied 15 years, 1 month ago 2 Members · 2 Replies
  • Rick Spencer
    July 13, 2011 at 12:43 am
    This post might be a little confusing. It says “end of file”, not end of tape.
  • Floh Peters
    July 13, 2011 at 10:38 am
    Sounds like you have a damaged media file somewhere. Try opening Media 100 with the “Shift” key pressed. This way you should be able to create a new project. Does this work? If yes, look into the media folder of the non-working project to see if there is a bad media file.
