Activity Forums Adobe Encore DVD “End of File” Error!
  • “End of File” Error!
    Posted by Gary Angle on June 17, 2008 at 9:53 pm
    I’m having trouble writing the DVD to a disk or a folder!
    It will build up to the same halfway point and throws up ‘End of File’!
    The entire Build is only about 2GBs.
    I did a check project and it’s clean of errors. Before the Build, I found several orphan timelines, which I deleted. I also found a button that was placed, but not necessary.
    What can the problem be, if I’ve come this far and get a clean Check Project?
    I don’t know where to start looking for a problem in the Building process! Nothing points at a problem!
    Thanks for any help,
    Gary
    Rob Paludanus replied 18 years, 1 month ago 2 Members · 1 Reply
  • Rob Paludanus
    August 11, 2008 at 6:45 pm
    Same problem here, with a duallayer project after writing 6.9 Gb out of the 7.87 needed i get this error.
    Who knows what to look for/repair if i check the project it gives no errors and/or broken links.
    Rob
