Activity › Forums › Apple Final Cut Pro Legacy › End Credits Roll // searched and searched w/ no luck
  • End Credits Roll // searched and searched w/ no luck
    Posted by Phil Yunker on April 11, 2006 at 8:58 pm
    I searched and searched for this tip here. I have a word doc with credits from the producer and I know there is a way to use the file along with adding an asterik * between the title and the person and then importing it into FCP and using the Text-scrolling text generator.. I can’t remember the next step.
    PHIL
    Thiago Lima replied 20 years, 5 months ago 5 Members · 6 Replies
  • Matthew Brunn
    April 11, 2006 at 9:26 pm
    I copy and paste the text into LiveType. Import .ipr and render.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 5.1/AE 6.5/DVDSP4
  • Phil Yunker
    April 11, 2006 at 9:36 pm
    Thanks. However, I know there is another way without using LT.
  • Gary Hughes
    April 11, 2006 at 9:48 pm
    I use other software to do this, but I saw this article that might help. https://larryjordan.biz/articles/lj_credits.html
    Gary
  • Kevin Monahan
    April 11, 2006 at 11:21 pm
    [PEYIII] “I have a word doc with credits from the producer and I know there is a way to use the file along with adding an asterik * between the title and the person and then importing it into FCP and using the Text-scrolling text generator.. I can’t remember the next step. “
    Actually, all you need to do is import it into Boris Title Crawl which is in your generators folder in most cases. If it’s not (likely you have FCP 4-4.5), you can install it from your install disk>extras folder>Boris Calligraphy. The tab stops should come in intact. Do not use the asterisk method in the standard text generator as there is not as much control and is a lot of extra work you can avoid with Boris.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
  • Phil Yunker
    April 12, 2006 at 1:20 am
    Thanks Kevin. I’ll try your method next time. I had already found what I was looking for before I read your post.
    Thanks.
    PHIL
  • Thiago Lima
    April 13, 2006 at 1:47 pm
    Hey,
    I try the astherisk method in two workstations and i have the same problem. When i aplly the the astherisk in the text that should be at the left of the screen (the astherisk is after the text on righ side) i have the error message out of range. When i aplly in the text on the other side no probvlem happens and the method works. Do you guys know what that should be?
