Activity › Forums › Adobe Encore DVD › encore transcode settings
  • encore transcode settings
    Posted by Arthur Klein on April 1, 2008 at 8:40 pm
    is there a way to let encore transcode from a qt ref file for normal m2v and to turn off the blu-ray transcode?
    i dont need blu-ray file.
    in audio transcode setting there is a dont transcode choice. I dont see it on the properties menu transcode pulldown menus. How do i only have it trancscode dvd?
    Jeff Bellune replied 18 years, 6 months ago 2 Members · 3 Replies
  • Jeff Bellune
    April 1, 2008 at 9:41 pm
    What is the frame size of your qt ref file?
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Arthur Klein
    April 2, 2008 at 12:07 am
    hi Jeff,
    Thanks for your response.
    i am using Encore DVD CS3 and the frame size through a QT Ref Avid DNX 220 encoded 1080x1920i 29.97. Encore reads Ref file fine other than i need to crop 6lines top and 6 lines bottom to get rid of Black on rt and lf frame (probably the difference of 720×486 / 720/480).
    How do i turn off the blu-ray encodeding? I only need the mpeg2 for standard def ntsc dvd.
  • Jeff Bellune
    April 2, 2008 at 1:33 am
    Resize your video in Avid to 720×480 before exporting. The frame size you are using will always be interpreted by Encore as Blu-Ray.
    -Jeff
