Activity Forums Adobe Encore DVD Encore Shrinks My Video
  • Encore Shrinks My Video
    Posted by Noforme on December 21, 2006 at 9:08 pm
    Hello,
    I imported a Mpeg 2 video from Adobe Premiere in 720 x 480 Format. It plays in the timeline great, but when I preview there are 2 large black bars on the top and bottom of the screen, and when I burn I get the same. How do I make it burn full screen? Thanks
    Eli
    Joe Bowden replied 19 years, 9 months ago 2 Members · 9 Replies
  • 9 Replies
  • Joe Bowden
    December 21, 2006 at 10:06 pm
    What’s the aspect ratio of the clip? And the pixel aspect ratio?
  • Noforme
    December 21, 2006 at 10:10 pm
    Well I created it in Premiere at 720*480
  • Joe Bowden
    December 22, 2006 at 12:19 am
    720×480 could be square pixels, or it could be DV 4:3 or 16:9. Which is yours?
  • Noforme
    December 22, 2006 at 6:35 am
    hmmm, I know it’s the preset in Premiere for DV 720 X 480. I’m not sure if it’s square pixels or not, is there a place I can check?
  • Joe Bowden
    December 22, 2006 at 3:21 pm
    Check your project settings…all that information should be there, including video codec used, audio bit/sample rate, etc…the more information you can provide, the better. Once we know what kind of file you are trying to use in Encore, we can then make a better assessment of what the problem may be.
  • Noforme
    December 22, 2006 at 3:51 pm
    I’m Using
    Editing Mode : DV PLayback
    Timebase 29.97 Fps
    720 X 480 4:3
    Pixel aspect ratio – D1/DV NTSC (0.9)
    Does this help?
  • Noforme
    December 22, 2006 at 4:34 pm
    So figured out what happens, I just don’t know how to fix it, When I import the Mv2 into encore it automaticaly switches the timeline to a 16:9 ration, I just don’t know why
  • Noforme
    December 22, 2006 at 4:38 pm
    Ok I figured it out, When I exported the project as an Mpeg 2 with the Adobe media encoder, I accidentlly hit the 16:9 aspect ratio, so even though the project was 4:3 it exported to a 16:9, Dang that was a pain! Thanks for the help, you got me thinking!
  • Joe Bowden
    December 22, 2006 at 8:08 pm
    Aha! I had a feeling it was something like that.
    Glad you found it, and thanks for the update.
