Activity Forums Adobe Encore DVD encore problems
  • encore problems
    Posted by Maribel Vigil on December 15, 2007 at 5:51 am
    I have about 3 hours of footage imported as an avi to encore to create chapters whn I export it to a dvd it takes about 5 hours am I doing something wrong or is it that slow
    Heath Firestone replied 18 years, 9 months ago 2 Members · 1 Reply
  • Heath Firestone
    December 20, 2007 at 6:01 am
    It will take a while to transcode 3 hours worth of footage, depending on your transcode settings, and processor speed. You can do the transcodes before you try to create the DVD, by right clicking on the clip, setting the transcode setting, then telling it to transcode now. The transcoding is converting the .avi file from whatever codec you are using, eg. DV, to MPEG2 IBP, which is a fairly processor intensive process, which can take several times realtime, depending on number of passes, and processing power of your machine.
    Hope this helps.
    Heath
