Activity Forums Adobe Encore DVD Encore freezes while building DVD
  • Encore freezes while building DVD
    Posted by Laura Petrella on August 24, 2008 at 7:07 pm
    It just started a few days ago. At first I thought my dvd burner was shot. After having installed a new one the same problem occurs.
    I start building a project to burn the DVD , it does all the normal steps, checks audio, video, build menus etc. and when it is supposed to start writing the dvd it freezes at a few MB. This is now happening with all of my past projects still in the computer. Can anyone help ?
    Laura P.
    Jeff Bellune replied 18 years, 1 month ago 2 Members · 3 Replies
  • Jeff Bellune
    August 24, 2008 at 8:08 pm
    Can you build a disc image or a set of DVD folders?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Laura Petrella
    August 25, 2008 at 12:30 am
    I built the disk image and tried to burn that one and it froze the same way. Should I uninstall ?
    Laura P
  • Jeff Bellune
    August 25, 2008 at 2:09 am
    If you built the image successfully, but then could not burn the image using Encore, then it’s likely there is some hardware or software conflict that is preventing a successful burn.
    Try the free program ImgBurn. It is a handy, lightweight utility that does one thing – burn disc images. In almost all cases, ImgBurn will succeed when other programs fail.
    -Jeff
