Activity › Forums › Adobe Premiere Pro › Encore CS6 is Crashing with Premiere Pro CC
Posted by Mike Slawin on August 22, 2017 at 11:40 amHi, I’m using PPCC with Encore CS6 and is crashing when I setup to burn either Blu-Ray or DVD.
I heard from Adobe that there is no more updates for this software. Does anyone have a compatible solution for this?
Maybe another program that works with CC? Thanks!Steve Brame replied 9 years, 1 month ago 3 Members · 8 Replies -
Steve Brame
August 22, 2017 at 1:43 pm[Mike Slawin] “using PPCC with Encore CS6”
Not sure how you are attempting this, as there is no availability of dynamic link between Encore CS6 in any version of Premiere Pro above CS6.
Here’s a good explanation of the process –
https://www.art.ucla.edu/digitalstudio/pdfs/premiere_pro_dvd.pdf
Steve Brame
creative illusions Productions -
Mike Slawin
August 22, 2017 at 2:18 pmHi Steve,
Yes I am doing it accordingly to the link you sent me. I go to media encoder setup my video encode to a drive then close down PPCC and go to the Encore program. Is there a later version like CC available for Encore?
When I was with PPCS6 it worked like a charm, now I am having all sorts of error windows and crashing going on.Thanks!!
Steve Brame
August 22, 2017 at 5:40 pmMy first attempt at a solution would be to uninstall and reinstall Encore. Also, if you have some older MPEG2-DVD files to try importing, might try that to see if you can isolate the issue to Encore. If the older files import without issue, it may be a factor of the current project’s encodes somehow causing the problem.
You could also try exporting from Adobe Media Encoder rather than from Premiere, or even encoding an AVI to see if that will import into Encore.
Steve Brame
Ann Bens
August 22, 2017 at 8:58 pmYou cannot import the Premiere CC sequence into Encore cs6. (there is no Encore CC)
You need to export as mpeg2 dvd files from Premiere and import those files (video and audio) into Encore.———————————————–
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Ann Bens
August 22, 2017 at 9:22 pm[Steve Brame] “https://www.art.ucla.edu/digitalstudio/pdfs/premiere_pro_dvd.pdf”
The tutorial is not accurate it shows export settings of a H.264 file.
Mike Slawin
August 22, 2017 at 9:31 pmThanks pros for all your help. I just reinstalled CS6 and will let you know what the outcome is with Encore.
THANKS!! -
Mike Slawin
August 23, 2017 at 12:30 amWell I did just that. just reinstalled the software, working great! Thanks.
One question, I did upload the 2nd DVD for the Encore content for the Library but all files aren’t showing up.
How do I access the rest of the files. Thanks again!!!!!!Mike
Steve Brame
August 23, 2017 at 11:55 amHadn’t even noticed, because up until that one pic everything is geared toward MPEG2-DVD. Strange that they would put an incorrect screen grab in such a tutorial, but then again, it IS UCLA.????
Steve Brame
