Activity › Forums › Adobe Encore DVD › Encore CS6 and multiple AC3 tracks
Posted by Jef Huey on January 10, 2013 at 9:45 pmI am trying to author a Blu ray with two AC3 tracks – a 5.1 and a stereo.
The result is 2 stereo tracks. Googling this seems to confirm that this is a common problem. One solution is to make sure that the AC3 assets are tagged as “Do Not Transcode”. I can not find a way to do this in Encore CS6. While that did seem to be an option for DVD, it does not for Blu ray.
Can any one point out anything I am doing incorrect? Are there any workarounds?
JefJef Huey replied 13 years, 8 months ago 3 Members · 17 Replies -
Bill Stephan
January 11, 2013 at 1:35 amJef,
Are you running Encore on PC or Mac? I ran into the same issue and found that Encore CS-5 and CS-6 on Mac has the option for “Do Not Transcode” in the drop-down next to the media, while Encore CS-5 on PC does not. I have not used Encore CS-6 on PC. All my 5.1 .ac3 files are DVD & Blu-ray spec-compliant.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Jef Huey
January 11, 2013 at 2:46 amI am on mac – OS10.6.8. I saw those selections in the DVD columns but not in the blu ray column.
Any other ideas?
Jef
Daniel Ludwig
January 11, 2013 at 4:14 pmJeff,
you need to look at your project-preferences. if your project was created using “PCM-Audio”-preset, then all your audio will be trascoded to PCM, as it was selected project-wide.you can´t change that afterwards – or in other words, you need to create your project from scratch.
encore only allow PCM or dolby digital audio
cheers
danny
Jef Huey
January 11, 2013 at 5:35 pmThanks for the info. I had set the project up with Dolby Digital as I knew that the files were being created as AC-3.
These AC3 files were created with Compressor. They work just fine in a SD DVD project created in DVD Studio Pro with the same basic structure. So I have a fairly high confidence level that they are correct.
Any more ideas?
Jef
Daniel Ludwig
January 11, 2013 at 10:03 pmoh – my good,
jef – I remember some other guys mentioned the same problem, that 5.1 within encore will result into stereo-sound – seem to be a (one more) bug within encore.please let me do some more investigations on that. I could have a deeper look into the projects and the resulting BDMV.
normally I create BDs using the pro-tools (scenarist, DoStudio or others).
keep you posted….
cheers
danny
Daniel Ludwig
January 14, 2013 at 5:33 pmshort update:
I created a short test-project with encore with 2 audio-trackt:1. dolby digital 192khz 2.0 stereo
2. dolby digital 256khz 5.1 surroundafterwards I took the multiplexed BDMV-folder and demuxed it using EasyBD, which also created a project-file straight away. within this EasyBD-project I could see, that both streams will be shown correct.
1. DD2.0
2. DD5.1also tested with a software-player – which showed DD2.0 and 5.1 within the on-screen-info.
as I haven´t got a 5.1-surround-sound-playback at the moment – I could only analyse what I could see so far – this is looking OK.
cheers
danny
Jef Huey
January 14, 2013 at 5:44 pmThank you for testing.
Could you possibly make a screen grab of your asset page for me?
I am trying to compare how assets are brought into Encore as I feel this may be a part of the issue.
Cheers,
Jef -
Jef Huey
January 14, 2013 at 10:33 pmGreat info. Thanks so much.
Here is my problem. I can NOT get my AC3 files to be “Don’t Transcode” and your screen shot clearly shows that you have been able to do this.
So — How did you do that!!! 😉
Jef
Daniel Ludwig
January 15, 2013 at 5:59 pmJeff,
if you created your AC-3-files using compressor they should be valid for BD as well, or your global project-transcoding-setting is set to PCM audio.could you please upload a small sample of your AC-3-files (2.0 + 5.1) so we could have a look at it.
cheers
danny
