Activity › Forums › Adobe Encore DVD › Encore CS6 and multiple AC3 tracks
  • Jef Huey
    January 15, 2013 at 7:14 pm
    Here is a screen shot of my project.
    When I try to change the transcode option for the audio, I do not get “Don’t Transcode” as an option. I get a whole list of video formats.
    Now when I selected the .h264 asset and went to transcode options it DID have “Don’t Transcode” as an option. Which I chose and seems to be working correctly.
    I can not post any of the audio files as they are client property and the project is in progress.
    Does this give you ANY clues?
    Jef
  • Daniel Ludwig
    January 15, 2013 at 9:12 pm
    Jef,
    could you please tell me which compressor-encoding-setting do you use? have you choose one of the presets or have you create your own?
    could you please export the settings (drag-drop) it out of compressor and sent it over (zipped) to my email, so I could have a look at your compressor-ac3-setting?
    here´s my email-address: info (ät) moviedesign.de
    there must be something strange within your ac-settings.
    cheers
    danny
  • Jef Huey
    January 15, 2013 at 9:32 pm
    Will do later today. Not at that machine.
    I wonder if it might be the data rate for the 5.1 AC3 track. Will have to check.
    Jef
  • Daniel Ludwig
    January 15, 2013 at 9:43 pm
    Jef,
    it´s not a matter of the bitrate, encore could import AC-files with the max. bitrate for AC3 which is 640kbit/s. there must be any other kind of problem with your bitstream.
    cheers
    danny
  • Jef Huey
    January 16, 2013 at 4:06 pm
    Ok, here is an interesting update. I misspoke when I said that the two AC3 tracks were created in Compressor. They were actually created with a Dolby product (not sure which one) by the DVD authoring department here. So I am pretty confident that these are totally compliant files.
    Also, I tested these files on a PC system running the same version Encore and both of them seem to import properly!!
    So either there is a bug on Mac Encore or I have a corrupt project (which would be the second time for this project).
    More testing and research to do.
    Jef
  • Jef Huey
    January 17, 2013 at 5:53 pm
    Just an update.
    I started a new project on my mac system. I imported the audio tracks first and they came up as I would want – with “Don’t Transcode” in both Bluray columns.
    In my initial project, I brought the video asset in first. Don’t know if that had anything to do with it. But it seems as if that project became corrupted somehow, because no matter what I did, I could not get the 5.1 audio file to show “Don’t Transcode”.
    Currently waiting on the .iso to burn to a BD-RE so I can start a QC.
    We will see.
    Jef
  • Jef Huey
    January 20, 2013 at 4:14 pm
    Ok – final wrap up.
    For what ever reason, starting a new project and bringing AC3 files in prior to video assets solved my problem and I seem to have a Bluray disc that is what I need.
    I am sure that operator error played some part, but I had a total of 4 corrupt projects where I had to start over from scratch to get a viable result. By corrupt I mean things like assets once imported could not be changed. Even deleting and reimporting would not allow changes. I also had one project where the menus became corrupt and I had to start them all over again.
    Encore just seems incredibly “fragile” to me. But it also seems as if there are not a lot of options in the low price range when you need a slightly more than basic Bluray output. And that statement ignores the whole issue of going to replication. I am just looking at simple presentation discs for clients.
    Thanks for the help all.
    Jef
Page 2 of 2
