Activity Forums Adobe Encore DVD Encore CS5.1 forcing transcode on Mpeg-2
  • Encore CS5.1 forcing transcode on Mpeg-2
    Posted by Bob Miller on May 24, 2012 at 4:24 pm
    Hello,
    I just received an mpeg-2 from a client to make his bluray with. I usually don’t have any problems with mpeg-2s. But, encore says that it needs to transcode the file. Whereas the audio he gave me says “Don’t Transcode” in encore.
    Below are the file details from the MediaInfo app.
    In Encore, I made sure the project matched the frame rate and resolution, so I’m not sure what I’m doing wrong. I’m using CS5.1
    Format : MPEG Video
    Format version : Version 2
    File size : 11.5 GiB
    Duration : 1h 31mn
    Overall bit rate mode : Variable
    Overall bit rate : 18.0 Mbps
    Video
    Format : MPEG Video
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Duration : 1h 31mn
    Bit rate mode : Variable
    Bit rate : 18.0 Mbps
    Maximum bit rate : 27.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.386
    Stream size : 11.5 GiB (100%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Eric Pautsch replied 14 years, 3 months ago 3 Members · 6 Replies
  • Jeff Pulera
    May 24, 2012 at 6:27 pm
    Hi Bobby,
    A couple of possibilities –
    1) the MPEG-2 file isn’t fully Blu-ray compliant
    2) Maybe your default encode preset in Encore is set to H.264?
    Jeff Pulera
    Safe Harbor Computers
  • Bob Miller
    May 24, 2012 at 6:31 pm
    Thanks for the reply, Jeff.
    1.) As far as I know this is the settings I always use. Short films seem fine. I wonder if there’s something weird with longer content?
    2.) My Default Transcode Settings are:
    MPEG-2, 1440×1080, Frame Rate: 29.97, Upper Field First.
  • Jeff Pulera
    May 24, 2012 at 6:36 pm
    Any chance either end of the video got trimmed at all in Encore? Any edits will force a transcode
    Jeff
  • Bob Miller
    May 24, 2012 at 6:39 pm
    Soon as I import it, in the project menu, it says that it needs to be transcoding. Before it’s even on the timeline.
    I’ve uploaded a shot of my settings and what it looks like in the project menu:
    https://dl.dropbox.com/u/10314417/encoresettings.jpg
  • Bob Miller
    May 24, 2012 at 9:19 pm
    Alas, it seems 29.97 progressive is not supported in Encore. https://forums.adobe.com/thread/421178?tstart=0
    I’m going to try and convert to 24p in Media Encoder and see if that works.
  • Eric Pautsch
    May 25, 2012 at 6:07 am
    If he’s already given you your encoded stream why are you worried about settings? What you need is the uncompressed original file and encode yourself
