Activity Forums Adobe Encore DVD Encore CS4 Crashes
  • Encore CS4 Crashes
    Posted by Jeff Manghera on July 3, 2009 at 4:43 pm
    I’ve had Production Premium CS4 installed on my computer for about 4-5 months now. I only got around to using Encore for the first time today. I can’t even open the program! It either crashes while launching or holds up while starting a new project. It crashes almost immediately when I try to load an older project. Anybody else experiencing this type on thing? Any suggestions?
    Pete Middleton replied 14 years, 8 months ago 8 Members · 16 Replies
  • 16 Replies
  • Jeff Bellune
    July 3, 2009 at 4:53 pm
    The quickest way to troubleshoot is to create a temporary new user account with administrator privileges, then try to launch Encore from that new account.
    If it works, then your App Data folder is corrupted in the original account. Deleting it (location varies by OS) should solve the problem because Encore will rebuild it on launch.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Evan Newsome
    July 4, 2009 at 5:16 pm
    where is this “app data” commonly found on windows? in an adobe/Encore folder? the user folder? windows folder?
    I am using win7 which probably is the same as vista’s location.
    Intel i7 920, Corsair 3x2gb= 6GB, Gigabyte GA-EX58-UD4P F8, NVidia 9800 GTX 512MB, CS4 bundle, Windows Win7 RC 64bit
    also PPro 1.5 on a separate WinXP HDD
  • Jeff Bellune
    July 4, 2009 at 5:55 pm
    What happened when you tried to launch Encore in the new user account?
    -Jeff
  • Evan Newsome
    July 4, 2009 at 6:50 pm
    It started but I have a million new problems like PremierPro no longer has Sony or Panasonic video formats as an option and won’t load any of my HD footage projects.
    I did a restore and got my HD formats back, but still can’t load Encore.
    where is this folder you speak of? In an Encore folder? Windows? User?
    I did a search and didn’t find “app data” file that screams Encore.
  • Jeff Bellune
    July 4, 2009 at 7:29 pm
    The fact that En started OK in the new profile is good. You can now delete the new user account that you created.
    In Vista, Encore’s app data folder is here:
    C:|Users|[your account]|AppData|Roaming|Adobe|Adobe Encore|4.0
    Rename the folder then launch En again. It should start normally for you.
    -Jeff
  • Evan Newsome
    July 6, 2009 at 4:34 pm
    thanks, In the end I just wiped the HDD and started fresh.. it fixed my other problems too.
  • Jeff Manghera
    July 6, 2009 at 6:00 pm
    Totally unrelated to the subject: I was noticing your system. Did you put it together yourself? How well does run (especially for NLE)? How much did it cost?
  • Evan Newsome
    July 6, 2009 at 9:56 pm
    yes I built it myself. Easy to do!!!
    System screams I can render a video and burn the dvd in “minutes”. I did a 1hr SD video burned on disk in 15 minutes or so. 2hr takes less than 30 minutes. (No more burning overnight with the old dual core)
    has been stable on beta win 7. I updated with Win 7 RC, everything was fine until I installed a new 64bit driver for audio card, (I believe.) problem fixed on reinstalling everything and skipping the latest driver for sound card, I guess the motto ‘if it ain’t broke don’t fix it’ comes into play.
    i7 920 chip $230 (now $199 at micro center)
    MOBO around $260 minus a rebate of around $15 @ newegg
    6gb memory kit around $110 @ micro center
    video card $130 minus rebate that has yet to show up @ newegg
    $90 750w power supply @ newegg
    $60 Case (cooler master)@ microcenter
    $40 250GB OS drive- nothing special just a 7200 SATA drive.
    OS still free but on order for win 7 pro =$99 @ newegg pre-order
    $25 OptiArc DVD drive
    so around $1000
    existing (moved over from old computer)
    500 x 2 for RAID drive setup
    other OS drive w/ XP
    later added LG BluRay burner for $140 @ newegg.
    win7 scores:
    processor scores a 7.4
    memory scores a 7.5
    aero used to score a 7.9 but scores 6 now (not sure why)
    HDD scored 5.5 (not suprised)
    (I am missing one test.. going from my memory)
  • Giellen Farah
    November 20, 2009 at 9:41 pm
    What if it doesn’t load? I have the same problem. But it doesn’t start with other account either.
  • Evan Newsome
    November 20, 2009 at 10:46 pm
    there is a known issue and a fix with Encore unable to select bu-ray or causes endless freezing
    https://kb2.adobe.com/cps/516/cpsid_51665.html
