Activity Forums Adobe Encore DVD Encore Crashes upon importing video assets
  • Encore Crashes upon importing video assets
    Posted by James Riehle on June 7, 2011 at 6:09 pm
    I own the adobe cs5 master collection suite with a valid serial, all programs work great with the exception of Encore. I originally had a “non-royalty based serial” issue but found a .dll patch. Now that i can access Encore i can build the dvd menu but cannot import any video without the program freezing and not responding.
    HELP! Please!
    Dumitrescu Radu-cristian replied 14 years, 5 months ago 4 Members · 4 Replies
  • Lance Lewis
    June 7, 2011 at 10:14 pm
    James,
    What is the format of the video that you are trying to import? Have you tried importing other videos of other formats and/or resolutions?
    Not sure if this is part of the issue or not, but I would try to import several other video files and see if any work. If it’s only one that doesn’t import, than you can at least narrow down that it’s a problem with that one. I have had “funny” problems on occassion over the years with certain files. I suspect, that in my case, the files were located on severly fragmented and mostly full drives. Saving two a new drive solved the problem.
  • James Riehle
    June 8, 2011 at 12:31 am
    The formats have varied, avi mov mpeg2 doesn’t seem to matter and as far as the drive that I’m working on, the computer hard drive is about a year old and about half full i run the disk defragmenter regularly, i also use a 1tb external that is less than a month old. I dont think its the drive space. Thanks though.
  • Minu Sharma
    June 15, 2011 at 9:31 am
    Hi ,
    You can try some things :
    1. Restart Machine.
    2. Delete Encore Preferences.( Can be found at Appdata>Adobe >AdobeEncore)
    3. Clean Media Cache files.( Appdata>Adobe>Common)
    Reply if you get any success.
    Minu
  • Dumitrescu Radu-cristian
    March 12, 2012 at 5:10 pm
    I have Mac Pro 1.1 2xdualcore3Ghz,8Gb ram,Snow Leopard updated running CS5 suite updated and a meet the same problem with Encore crashing on asset import,but a friend wich had the same problem on PC told me : ‘WAIT till around an hour and it will be working just fine’ and he has right Dear Lord,so the problem is a bug or something,i spend two full days with this issue testing and reinstalling two times all suite,,,but now i can encode and burn without any problem,Thx. to Alex my editor friend.
    Keep burning Blu Rays 🙂 Cristian, video-editor
