Activity Forums Adobe Encore DVD Encore Chapter Hightlights Button
  • Encore Chapter Hightlights Button
    Posted by Ronald Czarnecki on September 1, 2014 at 1:54 pm
    I duplicated some of the menu buttons and moved them apart. However the second one down is not highlighting with a blue line across. It did burn correctly with the DVD (shown here) however when I made a Blu Ray disc at 26 gb (had to use dual layer 50GB disc) the menu button did not highlight.
    Because I can not view the blu ray ISO file before I burn I would like to check as to what might be causing this before I make copies. I do use DVDFab but I guess you have to buy it to view the menus.
    Solved I deleted the button and duplicated a new one. Something must have been changed in the button properties.
    Ronald Czarnecki replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
