Activity Forums Adobe Encore DVD encore 2 / software error.
  • encore 2 / software error.
    Posted by Alek Panfilov on April 26, 2006 at 6:55 pm
    Hi all ,
    i’ve got a strange problem , got a big project , 4 lvl menu tree , about 1.2h of video with chapter playlist etc., anyway in project check everything is ok.
    but
    while trying to build dvd ( dvd disc/ folder/ img ) or while trying to preview project – doesn’t matter from where ,
    i’ve got a msg like this :
    internal software error: .\Navulator\CTimeMapBuilder.cpp, line 71
    and next one
    internal software error: .\Plans\TitlePlan\VIDEOTSLayout.cpp, line 828
    help please :/
    Greenweeed replied 20 years, 3 months ago 3 Members · 4 Replies
  • Alek Panfilov
    April 26, 2006 at 7:56 pm
    4 OTHER PEOPLE :
    C:\Program Files\Adobe\Adobe Encore DVD 2.0\ErrorMessages
    there is a whole list of encore errors , with a little explanation 🙂
  • Alek Panfilov
    April 27, 2006 at 8:22 pm
    Hi all ,
    well i’ve overpassed my yesterdays problem .
    Encore had a problem with playing a >chapter playlist< maked from chapters of main timeline with end-of-action of each >chapter marker< linked to >back to chapter menu< . I had to delete end-of-action's from each chapter marker and everything works fine right now, but sadly i can't make my video to go back to >chapter menu< after playing a part of video choosed from that menu. 🙂
  • Jeff Bellune
    April 28, 2006 at 2:05 am
    You should be able to do what you wanted. It works on my system. Each chapter has an end action that returns the audience to a menu, and the Chapter Playlist that you created serves as a Play All function.
    Since you can’t get Encore to do that on your system, try this:
    Delete all of the end actions for all of the chapters in the main timeline. Then make a separate Chapter Playlist for each chapter of the main timeline (except for the last chapter – let it play so that the timeline’s end action can execute). Set the end action of each Chapter Playlist and the end action of the timeline to return to the previous menu. Link the menu buttons to the playlists.
    You should be OK as long as you don’t go over about 18 or 19 Chapter Playlists from one timeline.
    -Jeff
  • Greenweeed
    May 14, 2006 at 5:38 am
    I got the same problem and I cant solve it. Even if I delete all chapters I still got the same errors as you had. Could somebody help me? Thanks in advance.
