Activity Forums Adobe After Effects Encoding in AE results in darker image than original
  • Encoding in AE results in darker image than original
    Posted by Marc Brown on May 18, 2008 at 8:33 am
    I’ve tried a few different codecs from withing AE and the result is always the same. Much of my composition is pure white – as white as Notepad. But when I play the movies, that white is now a sort of off-white. Very obvious when compared to Notepad or other white things the monitor’s displaying.
    Is there some setting I need to pick in order to get around this quirk?
    While I’m at it.. the Quicktime H.264 encoding thing gives two options: Single pass and multi pass. Unfortunately, one evidently cannot specify how _many_ passes, so it defaults to what I estimate to be 6 or 7 passes. Who the heck has the time to wait for that? Not me, even with a 19-second project. Is there a way of setting the number of passes? ;p
    Simon Bonner replied 18 years, 4 months ago 2 Members · 1 Reply
  • Simon Bonner
    May 18, 2008 at 12:09 pm
    Try reimporting the rendered footage and hovering your cursor over a white area. Doe the info panel register RGB scores of 255? If so, there’s no problem with AE – it could just be a monitor problem. In that case, you could play with Adobe Gamma in your control panel to create a customised colour profile.
    Simon Bonner
    youtube.com/simonsaysFX
