Activity › Forums › Avid Media Composer › encoding for web question
  • encoding for web question
    Posted by Justin Gray on February 13, 2008 at 8:10 pm
    Hello, I have a 10 minute video that I need to stream on a clients website. I plan on using flash VP6 codec and know that I need to deinterlace to footage upon export. Here’s the question. In my Avid export options window should I select single field? Since this will be viewed on a computer it needs deinterlacing but is single field the same thing as deinterlaced? Thanks.
    -J
    Justin Gray replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jon Zanone
    February 14, 2008 at 12:37 pm
    I wouldn’t exort single field – I don’t think that will do what you want. I’d try deinterlacing in your encoding program. If you have the time, I would definitely do a test (both single field and deinterlacing in your encoding program…)
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Justin Gray
    February 14, 2008 at 6:56 pm
    Thanks John. Indeed I was able to export lower field and then deinterlace in Squeeze. Thanks again and have a great day. -Justin
    – Justin Gray
    KLTV Promotions
