Activity Forums Adobe Media Encoder Encoder seems to run out of breath…
  • Encoder seems to run out of breath…
    Posted by Joseph M. c iii on February 12, 2017 at 7:23 am
    Media Encoder seems to encode fine, and then just takes a break…encodes again…takes a break.
    It looks like this:
    https://i.imgur.com/9LTPgUw.png
    The cpu usage is at 100%, ram goes up, gpu usage is at 41% and everything is going fine. The preview window is showing progress
    Then…
    you just see all 4 cores drop in usage, ram goes down, and gpu usage goes down. The preview window stops showing progress.
    Some breaks are only like 3 seconds, others are like 12. Sometimes they happen only a few seconds apart, and sometimes i get a short run between them.
    This is drastically increasing how long it takes to encode, and all i’m doing is just trying to make a video proxy. It seems to get worse the longer it runs, as it doesn’t happen on the 5 minute samples i tested with. This is a 1 hour length video.
    google doesn’t help because i get results for things like “force encoder to use 100% cpu” but my problem is that it is using 100% until it apparently takes a breather.
    I have the source on my SSD, and i’ve tried saving the output on seperate occasions to the SSD and then the HDD just incase it was a harddrive bottleneck. But that didn’t help
    if there is a name for this, please tell me. any clues on what’s going on? it’s a .ts file extension being output to a GoPro QuickTime/.mov file with all the settings cranked as low as they can go for speed.
    update: then i tried putting the source on the HDD and output to the SSD…same thing.
    View post on imgur.com
    Joseph M. c iii replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
