Activity › Forums › Adobe Encore DVD › Encode failed
  • Encode failed
    Posted by Ryan Hill on October 21, 2009 at 5:30 pm
    So I’m trying to put together a DVD with Encore.
    First time I rendered my After Effects video as a “Lossless” .AVI file, 1280 x 720, no audio. Second time I tried resizing it to NTSC DV Widescreen 720×480 and including the audio at 48 kHz, but it was still lossless .AVI
    Both times, I imported the files into Encore, added them to a timeline, but when I try to encode them, it fails. It does it right near the start.
    If I import an audio-only .AVI file it works fine, so I know it’s just video that’s giving me trouble.
    I’ve also now started trying random videos I have lying around, and the only ones that seemed to encode are .mov files.
    So I re-rendered one of my files as a .mov file with .png compression, and it at least got a majority of the way through before it failed, but it still failed.
    Anything else I can try?
    Ryan Hill replied 16 years, 11 months ago 2 Members · 5 Replies
  • Ryan Hill
    October 21, 2009 at 6:09 pm
    So I can export a short 15 second .mov file from AE and it encodes fine. If I export the full version of the same movie using all the same settings, and it fails about 2/3 of the way through. There’s 800 and 700 gigs free on either drive, so it’s not running out of space.
  • Ryan Hill
    October 21, 2009 at 6:15 pm
    Because of another “encode failed” thread I found on here, I’ve confirmed that all the files are contained in a path with short folder and file names with no spaces.
  • Jeff Bellune
    October 21, 2009 at 6:16 pm
    Check for failed case fans/other sources of overheat. Rendering is CPU and disk intensive; hardware problems can show up during rendering that don’t appear during less demanding tasks.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Ryan Hill
    October 21, 2009 at 6:50 pm
    And yet I’ve re-rendered from After Effects in 5 different formats and it hasn’t had any problems yet.
  • Ryan Hill
    October 22, 2009 at 4:52 am
    I got it to work. Instead of trying to render the files directly from After Effects, I imported all my videos into Premiere and used Dynamic Link to send them to Encore. And that solved whatever formatting problem or something and it successfully encoded first try.
