Activity › Forums › Adobe Premiere Pro › Enable to create output – PREMIER PRO CS3
  • Enable to create output – PREMIER PRO CS3
    Posted by Gustavo Cedeno on March 12, 2008 at 5:22 pm
    Hi, I´m trying to export a clip as QT( sorenson 3, 320*240 ), but show message: “ERROR COMPILING MOVIE”, Enable to create or open output. What is wrong… Rds.
    Gustavo Cedeno replied 18 years, 6 months ago 2 Members · 4 Replies
  • Jon Barrie
    March 12, 2008 at 11:18 pm
    Hi Gus,
    This is definitely a QT version error. I’m assuming you are using vers 7.4? That is the problem. Go back to version 7.3 you won’t have any render/export errors.
    – Jon 🙂
    How many editors does it take to change a light bulb?
  • Gustavo Cedeno
    March 13, 2008 at 12:24 pm
    Jon tks for your comments. This issue is referred when you ready to lunch export session in Premier, not in the Qt software. Or you saying that I´ve to Uninstall QT latest version?
    — Answer: 0
    rds,
    GC
  • Jon Barrie
    March 13, 2008 at 9:48 pm
    You need to uninstall the latest QT. and then download and install 7.3.1 from this link for PC here
    – Jon 🙂
  • Gustavo Cedeno
    March 13, 2008 at 10:18 pm
    Thank you very much Jon, I´ll tell you about result as soon as possible.
