Activity Forums Adobe Illustrator Enable Illustrator CS 6 access to fonts rtxmi, wasy10, rtxr, and txsy
  • Enable Illustrator CS 6 access to fonts rtxmi, wasy10, rtxr, and txsy
    Posted by Helmut Haase on August 11, 2013 at 4:27 pm
    Hello AI experts,
    I have to put into graphics math formulas and symbols which shall look exactly like they do in the LaTeX-generated pdf document which is to be illustrated.
    The way I used to go is to produce a pdf page with formula elements by pdflatex (MikTeX). This document is o.k.. When I try to open it in AI CS6 a message tells me that fonts rtxmi, wasy10, rtxr, and txsy will be replaced by other fonts – which is exactly what should not happen. All my attempts to install the missing fonts have failed – in contrast to otf and pfm files. The problem fonts are type 1 fonts, same type as the uncritical ones.
    The alternative *.inf or *.pfm fonts which have been recommended are not on my computer. For the wasy10 font I do not even find any simlar file containing the string wasy10 – but it is in the pdf. Can anyone give me a hint what to to here?
    Kind regards
    Helmut Haase replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
