Activity Forums Adobe After Effects Expressions Enable Clamp Expression on a linked value?
  • Enable Clamp Expression on a linked value?
    Posted by Michael Müller on February 8, 2018 at 3:10 pm
    Hello community,
    I’ve got the following problem (added an image to make it more clear):
    As the ball moves, it’s position in the comp is tracked by a null with the toComp expression on its position value.
    I want the red paddle on the left to follow the ball’s Y Position, so I pickwhipped it.
    I also want the paddle to stop at a certain value, so it doesn´t go outside the comp in case the ball reaches the top.
    The paddle currently is connected to a null.
    On that nulls Y Position I’ve added
    thisComp.layer(“BallTrack”).transform.position[1];
    to track the movement. As soon as I add a clamp expression (for example clamp(transform.yPosition,-225,600)) the value is stuck at (in this case) 600.
    I’ve tried several things like putting it before or inbetween, nothing seems to work.
    I’m pretty much at a beginner level and this is my first post on the forum, please go easy on me.
    Thanks a lot
    -Michael
    thisComp.layer("BallTrack").transform.position[1];
    Dan Ebberts replied 8 years, 6 months ago 2 Members · 3 Replies
  • Dan Ebberts
    February 8, 2018 at 5:18 pm
    You want to clamp the result of the first line, is that correct? You could do it like this:
    y = thisComp.layer(“BallTrack”).transform.position[1];
    clamp(y,-225,600)
    Dan
  • Michael Müller
    February 8, 2018 at 7:34 pm
    Thanks Dan, that was just what I needed!
    Probably I should get into the habit of creating variables instead of pickwhipping, I wasn’t aware of the fact that this could mess up an expression.
  • Dan Ebberts
    February 8, 2018 at 7:38 pm
    Yeah, without the variable, the result of the first line gets discarded.
    Dan
