Activity › Forums › DaVinci Resolve › enable cache mode?
enable cache mode?
Posted by Blase Theodore on October 28, 2010 at 9:40 pmHas anyone found where the can toggle through differnt render cache modes? I’m only seeing the menu dropdown “render cache mode”.
Blase Theodore replied 15 years, 11 months ago 3 Members · 6 Replies -
Dwaine Maggart
October 28, 2010 at 10:13 pmThe Option key + R key will toggle the render cache modes.
Currently, there appears to be an issue in 7.0.2 with Cache ALL mode, so I would recommend you not use that right now.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Blase Theodore
October 29, 2010 at 12:38 amYes but there are multiple render cache modes. The toggle only works for render all.
Dwaine Maggart
October 30, 2010 at 5:52 amOn my system, Option r toggles through all the cache modes.
I should add that I am running software 7.0.3 beta 2, and it’s possible that if you are running an earlier version, like 7.0.2, maybe it has that problem. I did not have a chance to load that back in and test that.
Dwaine Maggart
Dwaine Maggart
October 30, 2010 at 4:52 pmWhat I read into the responses above (perhaps incorrectly) was that Blase was using Option r, but it was only toggling Cache All on and off. If someone else running 7.0.2 could try Option r and report what they see, that might be helpful.
Dwaine Maggart
Blase Theodore
October 30, 2010 at 5:01 pmHey Dwaine,
not sure how or why, but it works now. I can toggle through all options fine. Not sure what changed.
