Activity Forums Maxon Cinema 4D emitter objects
  • emitter objects
    Posted by Philip Hibberd on January 25, 2010 at 7:18 pm
    I placed an object (rose petal I made in c4d) into an emitter sending the petals from bottom to top in a simple float and rotation. Looks great when I show objects, but when I render out a mov or picture there are a lot less petals. In the preview there are 100s but in the render only 10?
    Using the petals as a wipe transition so need them to fill the frame.
    any suggestions.
    Philip Hibberd replied 16 years, 7 months ago 1 Member · 1 Reply
  • Philip Hibberd
    January 25, 2010 at 7:37 pm
    Found it. Birthrate Renderer. How many times do I forget that one.
    I needed to set the birthrate renderer to the amount I wanted visible in the final render.
    sorry.
