Activity › Forums › Apple Motion › Emitter growth
  • Emitter growth
    Posted by Dan Davis on April 15, 2009 at 2:05 am
    Hi, need some help.
    I’m applying a fire blaze (particle) to a scene. When I cut to the scene I need the fire blaze
    to be in full flow and not to grow (emit) from nothing. In Combustion the way I do this is
    by using preload frames. The whole project is built in fcp and motion so I need/want to
    stay with motion.
    Thanks for any help.
    Danny.
    Stephen Smith replied 17 years, 5 months ago 2 Members · 1 Reply
  • Stephen Smith
    April 15, 2009 at 2:59 pm
    Simplest way I think to do it is to move the group to the right so the blaze starts where you want it. If you can’t do that then animate the opacity so in one frame it is set to zero and then in the next it is set to 100%. This way you don’t have to alter any of the setting you already like. Hope this work around helps.
    Salt Lake Video
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
