Activity › Forums › Boris FX Particle Illusion › Emitter direction
  • Elvis Deane
    July 13, 2007 at 4:51 pm
    If you go into the Properties, you can change the angle under the Behaviour tab>Particle Angle, by changing the Offset number. Adjust the width with the Range slot.
    The reason for that is that the Emission Angle controls the direction the particles leave the emitter if they have Velocity. In this case, the particles aren’t moving, just growing over their life.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Les Stella
    July 14, 2007 at 1:32 am
    Thank you – very much appreciated.
